Looking good @duerer! I’ve only got 2 notes:
- The wing feathers’ alpha is a bit fuzzy and I can still see the sharp edge of the geometry. I recommend adjusting the contrast of the alpha so the geometry edge is hidden by the “hairy” edge of the feather pattern.
- The feather material desaturates the red color so it looks noticeably different from the underlying diffuse texture. The diffuse texture is like a backup in case the viewer sees through the feather groom so it should match a bit better. Admittedly I can’t remember if I address this later in the course but just so you know that it’s best if they’re more consistent visually.
