Reply To: Grid Fill causing corner bulges even after subdivision – how to fix?
Forum Archive Grid Fill causing corner bulges even after subdivision – how to fix? Reply To: Grid Fill causing corner bulges even after subdivision – how to fix?
#96602
    Hi Deb,
    You can try this: in Edit Mode, SHIFT+ALT+S > To Sphere and then Move your Mouse to the right (or just press 1).
    After that, you’ll have to use Proportional Editing again, to get the ‘bell’ shape back.
    However, it is probably better to not use Grid Fill for this; Grid Fill works best for flat patches. Concentric rings will work better, something like this:
