Reply To: Grease pencil edit extrude : odd behavior
Forum Archive Grease pencil edit extrude : odd behavior Reply To: Grease pencil edit extrude : odd behavior
#77628
Paul Caggegi
    If you’re using the pencil tool, any pressure sensitivity should override this, and is controlled by the “Radius” option. Toggling the Pressure sensitivity icon nest to it will enable/disable this.
