Reply To: Grass blade of Hell
Forum Archive Grass blade of Hell Reply To: Grass blade of Hell
#98942
    Try changing the Values (Strength and Distance) in the Bump Node. The size of your grass blades, for instance might be a bit different from the ones in the Course. Don’t just Copy the Values used, but use them as a starting point and change them untill you get what you want. (I know, this can be very frustrating at first, tweaking the Values of all those Nodes and trying not to make more of a mess, trying to remember what each Node does and how changing a Value in one Node changes the result, but that’s just the way it is….it will get easier over time, I promise).
    Also, if I remember correctly, Kent switches out the Bump Node for a Displacement later on in this Lesson.
