Reply To: Forgetting to override?
Forum Archive Forgetting to override? Reply To: Forgetting to override?
#90115
Wayne Dixon
    Hey Carlos,
    @wod is correct in the functionality aspect of this.  It only ‘visually’ affects the way it is displayed in the viewport.  Its position, scale and orientation is displayed at a different spot.  This visual aspect has no effect on the functionality of the rig at all.
    In the context of the tutorial however, the main issue I had was that I had created to the widget before overriding the display.  This meant I had to adjust the widget a second time.  If I had of overridden before adding the widget, I could have just adjusted the widget shape once. Nobody likes doing things more times than necessary.
