Reply To: Fixed? Disappearing textures on close-up
Forum Archive Fixed? Disappearing textures on close-up Reply To: Fixed? Disappearing textures on close-up
#37541
Jonathan Gonzalez
    I assume this only happens when animating? If you move your camera out further from the character does it cut out still? The checkbox you selected and the animator setting should be all that is needed for that. You could also try a different shader to see if that is causing the issue as well. I don’t know if you are using any kind of culling but those are the only things I can think of that would affect the rendering of the object.
