Reply To: Faces,Vertices and edges shortcut not working
Forum Archive Faces,Vertices and edges shortcut not working Reply To: Faces,Vertices and edges shortcut not working
#76319
    That shouldn’t happen. Be sure you are in edit mode, because if you’re in object mode it will switch between your collections. Also be sure you’re pressing the numbers at the top of the keyboard, not on the numpad to the right.
