Reply To: Faces not appearing perfectly flat in final touches
Forum Archive Faces not appearing perfectly flat in final touches Reply To: Faces not appearing perfectly flat in final touches
#90801
    Hi Al Mar @Tachy ,
    Those Shading issues were caused by the insets around the buttons and mostly around the d-pad; they were probably not deep enough (blue lines), so the angle between the Faces on both sides of the yellow lines was less than 30° and thus ‘shaded smooth’, causing those artifacts:
    I hope that makes a bit of sense.
    Anyway, your solution works well too; sometimes auto-anything doesn’t do what you want and needs to be ‘corrected’ 😉
