Reply To: Face mounth shape
Forum Archive Face mounth shape Reply To: Face mounth shape
#77502
    The shape of the mouth looks good from front view Max. Maybe it could be a bit wider…
    What I would do (and did), is re-doing the first 4 lessons a few more times; that is the base, you are going to work with and it should be as good as possible. Save all those .blend files so you can later look at the improvements you made. But of course everybody has a different way of learning; it’s completely up to you
    As to your earlier question regarding the head shape, compare this (my head is far from perfect as well!):
