Reply To: extrusion will only scale from the center of last edge I’ve selected
Forum Archive extrusion will only scale from the center of last edge I’ve selected Reply To: extrusion will only scale from the center of last edge I’ve selected
#74787
c0Vₑ
    that really helped. I’m sorry you had to figure that out on your own since the dropdown disappears when I scale it. I’m also having issues with beveling the vertices
    when I try to bevel the screen. it doesn’t look even like yours does in the video:
    and the control bar looks like this, so if you happen to see anything that looks out of the ordinary then maybe you could spot it:
    I’ve tried copying this video on YouTube as well and it didn’t quite solve the problem:
    https://youtu.be/TPnPrXPS1-k
    sorry that I’m coming up with so many issues, and if you think you need any more photos of what’s happening on the project then I will gladly send you more screenshots. I am willing to restart the entire project if necessary, but otherwise thank you for your time.
