Reply To: Error: Failed to insert keys on F-Curve …
Forum Archive Error: Failed to insert keys on F-Curve … Reply To: Error: Failed to insert keys on F-Curve …
#86476
Wayne Dixon
    Oh that’s really interesting Shay.
    Annoying for you yes – but interesting because you may have found a bug
    Thanks for this video because it is clearly showing the error and not the workaround you were using.
    Can I ask a few questions to help resolve this….
    • Does this happen when you open a fresh file and you do the same process with the default cube?
    • Is it possible for you to post that exact file (from the video) somewhere we can grab it. (like Dropbox etc)
    If the same thing happens on the default cube and this file for you, but not for us, then it’s likely something to do with your setup.
    You can try resetting Blender back to the factory settings and seeing if that fixes the issue.  If you haven’t changed many settings away from default or your not afraid of losing all your preferences, you can do that now.
    But if it’s annoying to set it up the way you like, then wait until we have the same issue (or not).  Or you could download one of the latest builds and test it on that (with factory settings – don’t import any preferences if Blender asks).  This will be a workaround as to not wipe out your settings on the current stable version if you don’t need to.
