Reply To: [ENDED] BC4-1810 – October 2018 Class Homepage – Shading & Lighting with Blender
Forum Archive [ENDED] BC4-1810 – October 2018 Class Homepage – Shading & Lighting with Blender Reply To: [ENDED] BC4-1810 – October 2018 Class Homepage – Shading & Lighting with Blender
#41682
John Sanderson
    @yukinoh1989 just saw your nodes in your other post.  Here is a node set up that can work with the mix shader.  I just used a noise texture to generate the mask, but if you wanted a specific pattern you would just need to crush the levels on your diffuse input with a color ramp. Good Luck!
