#35596
William Miller
    For some reason, the curves won’t work.  If I try to give them thickness in the curve properties, it gets a little bit of thickness, but then it stops.  The same thing happens to objects I use a curve modifier on.  Also, I’m out of ideas for how to connect the hover thrusters with the arms coming out of the side of the tank.  Could you help with that?
