On Blender 2.8.. I think the idea is that if you’re on another tool group, using the hotkey for the group would pull the active, while a second press would cycle through, though as we noted, it doesn’t loop on that cycle (which, don’t mind the cycle as long as they looped it). So, for example, if you’re using the clay group and have clay strips as your active for that group and want to switch to the inflate group (with inflate as the “active” of the group), pressing i would switch to that group with inflate as the active. Then pressing c would make the clay group with the strips as the active. I think that’s the intent. As we’ve seen, it’s not always consistent on this behavior, but since it’s still in Alpha and they’re focused on showstoppers (ie things that crash), I’m going to be patient and wait.
Either way, it is even easier to click on the one you want than it used to be and I like the sculpting workspace they have now.
