Reply To: Draw sharp problem
Forum Archive Draw sharp problem Reply To: Draw sharp problem
#53355
    If you find your geometry is stretching that’s a clear indicator that you’re using the Crease brush. The only difference between crease and draw sharp is the pinch behavior.
    Switch to the Draw Sharp brush to avoid the pinching.
