Reply To: Does the 3rd way make the low poly mesh slightly bigger?
Forum Archive Does the 3rd way make the low poly mesh slightly bigger? Reply To: Does the 3rd way make the low poly mesh slightly bigger?
#56029
Jonathan Lampel
    The low poly object should stay the same size! If you use the displacement modifier then they can be instances of each other since modifiers won’t affect the other instances. If you inflate the cage in edit mode though, it’ll have to be a Shift+D copy instead of an Alt+D instance.
    Hope that helps!
