Thanks a lot for your reply! The issue is not related to the course content, I guess. I didn’t know that multires is necessary to even see the option of displacement bakes (which makes sense to me now: After I applied the subdiv modifier and implemented a multires modifier on the same model, it baked without the error message and displayed the correct option (in Cycles). It’s still not working 100%, for some reason there is no data transfer but the character I built has several different meshes, so I’ll just repeat the process with other meshes first (some are built with multires according to a prior course which is why I entered this course :-). As for the Scale: Do you apply it each time you applied any scale on a mesh? I thought I could apply it only once at the end of the modeling process to clean it up? Thanks a lot for your quick replies!
