Reply To: Dices: how can I separate dots from the cube
Forum Archive Dices: how can I separate dots from the cube Reply To: Dices: how can I separate dots from the cube
#93005
    …and if you don’t want to change the Keymap, you can also do a Select > More from the Menu and then SHIFT+R a few times to repeat that last action…
    …or, right-click on the Select More and then Add to Quick Favorites.
