@spikeyxxx thanks a lot apparently i counted not right , 24is the edge count , i ended up with 16 vertices so i guess that is great.
i do have one question , right now the bottom will be also having the yellow dot . should i try to fix that or wont that be noticed?
then for the lower part of the flower should i also use the same technic or should i here work with a 5 sided mesh?
or is that depending on the type of flower ?
like with this i could use the same technick but if the flower points downward i should work with someting to create some volume ?
