Homework Submission – Week 3 – Mountain N
@adrian2301 @jlampel
Hi guys. So I finished painting the maps. Here are the results:
Color map:
Cavity map:
Normal map:
My normal map is 1024×1024 instead of 512×512 like the others because a 512×512 normal map just looks way worse. I hope that is not a problem.
here is how they look when applied:
I also used a ColorRamp node to get a slight roughness difference between stone and non-stone areas. I kept it at that because I wanted to keep the node setup as simple as possible. Here is the setup:
I hope this fits the final sceen. If there is anything to improve just tell me. it has been a blast working on this mountain! 😀
