Reply To: Collab2021 – WIP – createtaiwan
Forum Archive Collab2021 – WIP – createtaiwan Reply To: Collab2021 – WIP – createtaiwan
#65135
    would the duplicates that share the data of the originals still contain the linked data
    @createtaiwan  Yes linked duplicates still source correctly when linked even if they’re in another collection 👍
    You’ve done a masterful job with the fence, sir. The quality is fantastic, efficiency of the model structure is ideal, and your dedication to matching the art is stunning. You’re done as far as I’m concerned. Awesome work! 🤝
    I’ve a couple thoughts about the fence right now concerning the layout. In two ways it’s unlike any fence I’ve seen:
    1. Rounded: I can’t recall seeing many curved fence layouts in reality. They may have a curved section, like following a road or something. But they primarily fit a polygonal shape with corners since most property lots are sectioned off this way.
    2.  More open than closed: By definition fences contain something, whether animals or property boundaries. Some yards use a small section of fence as decoration but by “small” I mean only the corners of the property or supplementing a gate; meaning maybe 10% of total fence-able area.
      The fence layout currently is a bit purposeless in this way; not closed enough to contain anything yet too populated to be mere decoration.
    Right now it’s just some thoughts; not really sure the best route. Do these points even matter? As I continue fleshing out the scene and figuring out the ground (roads) it’s possible I will alter the layout a bit. But I will close with saying again, the way you matched the art is very impressive and commendable!
