You uploaded your .blend1 backup file, try having your normal .blend in the folder. Also in Edit -> Preferences, under Save & Load, I put “Save Version” to zero (0), so we don’t have the .blend1 and .blend2 cluttering up everything.
Also you forgot to pack in the texture, at least it was like that in the .blend1. But I don’t know if that was what you were going for.
In the IMAGES folder there’s an OBJECTS MEASUREMENTS folder. There you’ll find some images with real objects dimension that should guide us for working with good scale. I imagine with time that folder will grow.
