Reply To: COLLAB2021 – HQ – Stylized Fantasy Environment
Forum Archive COLLAB2021 – HQ – Stylized Fantasy Environment Reply To: COLLAB2021 – HQ – Stylized Fantasy Environment
#63489
splat21
    @spikeyxxx One last comment before I heed KT’s advice and no longer post this conversation in the HQ thread.
    I did check out 2.93’s GNs.  I’m loving the future.  Mesh Primitives seems pretty cool.  I mean, you can Add a Plane, delete three vertices and with one create a complex object within Geometric Nodes.  What is not to love?
    I did look at the Spreadsheet view.  I don’t believe that it’s functionality is what I was looking for.  I am looking for a way to view the output value of a Math node.  For example, as you camera zoom into the object, how do you know the value of the Math-Ceiling node going into the Ico Sphere’s subdivisions input?  Is it 0, 1, 2, etc. ?  The only way you would dial in the right values is by experimentation via changing the numerator in the Divide node.  I suspect that that is how you landed on the magical 10.3 value.  If the Spreadsheet View does indeed allow the monitoring of node outputs, I am not seeing it.
    Thanks again for this dialog – it has been very enlightening.
