@spikeyxxx I am trying to duplicate your geometry nodes. This is my first experience with it. I look at this as a great opportunity to learn!
1) Please confirm my understanding of the end goal: As you zoom in closer the subdivisions increase on the Ico Sphere (wunderbar!).
For those following at home, here is what I did. Used a split screen like using a Shader workflow. Top is the 3D Viewport and the bottom is a Geometry Node Editor. Added an Ico Sphere to my 3D viewer. In the Geo Node Editor, pressed the New button and removed the Group Input node. Added and hooked up the nodes to duplicate your configuration. Except…
2) I can’t find the “Ico Sphere” node – where do I get it? I have looked at (I believe) every single node available via Shift-A, but it has eluded me. Also, in the Geo Node world, is this considered a “shader” node (e.g., it has green connections)?
Cheers
Splat
