#54593
Shawn Blanch
    So, yeah. I typically agree with Kent by using a bezier circle as the template “Bevel object” because you can control all hydraulics that are using it dynamically rather than going through them 1 by 1 by 1 by 1 by…………ugh….
    Yeah @adrian2301  the diameter is just double the radius so dividing the “Bevel Depth” would work but again I already created 2 Bez circles as templates for the diameter if you just want to assign those. I can put them in their own collection next to the other hydraulics collections. Then @pfbourassa and @adrian2301 and @blanchsb and whoever else can all use the same template if a decision comes later to change the hydraulics’ diameter….. We would just adjust the circle’s diameter and everything else would be adjusted (except the fittings).
