#54337
artifact
    @blanchsb
    I don’t think you’ll have to spread the loader arms out much further. I believe the problem lies with my initial extrusion to a detail I should have inset instead. I’ve highlighted the offending extrusion in red below at the 1st clash of the blends point.
    Insetting that detail plus narrowing the engine enclosure by a hair towards the back should sort that problem right out. Unfortunately I’m unable to work on the model until this weekend.
    @adrian2301  Thanks for the top view find. The taper @luthier had talked on the stream about was towards the front of the enclosure instead of towards the cab. Still, from the top view reference you found, it does seem that the part of the enclosure with that inset seems a bit narrower than the rest of the enclosure towards the back.
