Your loader arm is looking great, Shawn. I’ll be happy to cover the circular cuts in rounded surfaces bit. Could you snap a screenshot of the “grease port” that you’re describing so I can approach it most relevantly?
but it probably means most of my low poly parts will need an applied subdiv to use the trick a little better?
Unfortunately applying a level of subsurf is often the only option, depending on the level of curvature. Looking at your arm pieces I don’t see much curvature…so I’m curious about the specific area you’re referring to.
