@ketre as you can see from this image, the left most window does curve quite significantly from top to bottom and from front (above the high point of the wheel arch (fender)) towards the bottom left corner, which would look like a bulge from the rear view. The important thing is what it looks like in 3D / perspective view, when you enter front, back or side view you switch to orthographic view which is flat 2D. Try and asses your model by panning around in 3D to see where you can smooth out any areas, maybe add a subsurf with 1 division. Keep it up. It’s not a contest we are all here to learn and support each other. 👍
