Reply To: CGC Challenge Juli 2019, Vehicle WIP
Forum Archive CGC Challenge Juli 2019, Vehicle WIP Reply To: CGC Challenge Juli 2019, Vehicle WIP
#47930
    @williamatics Hi William, I use a ‘mould’, for instance, I have a ‘head_shape’ mesh. Then I use snapping to surface and a shrinkwrap modifier to make the topology I want. Now I can, for instance create edges, where I want a separation of panels. What I did was, I made a vertex group called Solidify and assigned those edges to it. Made a solidify modifier after the shrinkwrap and used the Solidify vertex group ( with settings to ‘Fill Rim’ and ‘Only Rim’). Use CTRL B with a number of three on those edges and select the middle one.
    Now comes the genius part: I select those edges and press ‘V’ and my panels appear!
    I know this is not a very clear explanation ( not like Jake Korosi’s!), but if this is not clear to you, I will try to explain it better, with some screenshots.
    Just let me know if you want that.
