Reply To: Can’t see vertices when resizing edge loops with s,x
Forum Archive Can’t see vertices when resizing edge loops with s,x Reply To: Can’t see vertices when resizing edge loops with s,x
#98112
    Hi David @RavenMenace ,
    You can also move the “X-Axis Scaling Guide Line” (this is probably not what it is called officially) out of the way, by Changing your Transform Pivot Point to the 3D Cursor:
    That is less ‘destructive’ than making the Vertices larger, which can get problematic, when your model gets denser:
    Then you’ll have to change it back and changing a Preferences Setting back and forth is not ideal😉
