Forum Archive › Cannot edit all the linked ducts at once ( I did use ALT D) › Reply To: Cannot edit all the linked ducts at once ( I did use ALT D)
Hey @cherryholmes ,
You only need to select one duct, then enter edit mode.
If you SHIFT select all the ducts you can only edit the active object, the last one selected, even though all the objects are in edit mode.
Hope this helps
