Forum Archive › Can you change what object an instance is linked to or unlink it altogether? › Reply To: Can you change what object an instance is linked to or unlink it altogether?
And as you say, apart from unlink, you can change the instance the object is linked to. You can go to the same place where Martin shows in the image and from the drop down menu select the desired object data.
