Reply To: Both highlighted objects rotate, when I only want one to rotate.
Forum Archive Both highlighted objects rotate, when I only want one to rotate. Reply To: Both highlighted objects rotate, when I only want one to rotate.
#72251
Jonathan Lampel
    I’m not entirely sure without looking at the file… Just to double check, are they separate objects? If they are linked duplicates, are you rotating them in object mode rather than edit mode? In the video I just have one object and am duplicating the parts in edit mode.
