Reply To: Both highlighted objects rotate, when I only want one to rotate.
Forum Archive Both highlighted objects rotate, when I only want one to rotate. Reply To: Both highlighted objects rotate, when I only want one to rotate.
#72253
    It looks to me as if you only have 1 Object. To rotate part of that Object you need to go into Edit Mode.
    Look at the outline color.
    Here are some situations and places that gtell you what is going on; 2 separate Objects:
    2 linked Objects:
    And 1 Object:
    The info in the top left corner of the viewport is an Overlay, that can be handy sometimes (I leave it off most of the time):
