Reply To: Boolean With Ico Sphere
Forum Archive Boolean With Ico Sphere Reply To: Boolean With Ico Sphere
#73754
    @mrorangekitty seems to work perfectly fine, if this is what you mean:
    (Also Applying the Modifier and deleting the Cylinder works as it should.)
    What Blender version are you using?
    Or did you maybe use a Cylinder with a hole? It should be a ‘closed’ (watertight) Mesh.
