Hi Jesse,
You are probably just misusing that Matcap; there is nothing wrong with the Model, as far as I can tell.
Use a Material (even a Principled BSDF will work) and look at it in Rendered View, maybe with an HDRI for Lighting. Use Auto Smooth Shading and play with the Threshold Angle, if necessary. It’ll probably look perfectly fine then.
