Forum Archive › Beveling an Edge Through Another Beveled Edge with Multiple Segments › Reply To: Beveling an Edge Through Another Beveled Edge with Multiple Segments
It’s the normal calculation. You can reduce it by adding an edge loop and then slide it until has a smoother transition. you could also manually adjust the normals but that is hard then it sounds. Also make sure you don’t have any flipped faces.
