Reply To: Bevel Edges Back to Straight Edges
Forum Archive Bevel Edges Back to Straight Edges Reply To: Bevel Edges Back to Straight Edges
#85577
    You would basically have to remodel it. One tricky way would be, if you double tap G you go into edge slide mode, and then if you hit C you get an extension of the slide and that way you can get the beveled vertices back to where they meet up.
    Also there is an addon that has a lot of useful tools to unmake this kind of bevel and other things. It’s called Mesh Machine, linking you up:
    https://blendermarket.com/products/meshmachine
