Reply To: BC4-1810 – October 2018 Class Home Work – Sparkes983
Forum Archive BC4-1810 – October 2018 Class Home Work – Sparkes983 Reply To: BC4-1810 – October 2018 Class Home Work – Sparkes983
#42937
Sean Parkes
    @silentheart00 I kept it quite simple. As attached. Really only tried to play with some settings in the noise texture node. Still quite green on the node editor, so didn’t try too much. Tried plugging the  noise texture into different nodes, found tinkering a little helped. Which nodes did you incorporate ?
