@smurfmier1985 Thank you so much miranda. i sure did my best . trough i still wonder about a few things that i cant figure out .
maybe some can help me with these questions.
1: on the front wheel you see 4 small lightblue dots does anyone know what is causing this ? is it the light ? someting of the node setup ?
2:somehow you see the dust but i like the effect better on the floor then on the toy. not sure eighter here why that is diffrent 🙁
3: is it possible to use the node wrangler in 2.8 ? i know kent used it but somehow its not working in my 2.8 file 🙁 so its hard to see some effects without the black and white value
4: is it possible to change the offset of the scratches ? so they are further placed from each other ?
5: as you see for the dirt somehow at the side of the toy it isnt appearing while in front it does appear. can this be fixed ?
6:if for example i want to use a scratch motive like this but want to add depth to them so its more like real scratches how could this be done
7:another one of the scratches. is it possible to set a certain collor for the scratches ? now they are darker then the base but what if i want to use that effect of the setup but more want to let it look like a kid painted with collors on the truck how can you set collors for that ?
sorry for the bunch of questions . but i tought that its better to add them here again . sometimes i didnt knew anymore where i asked a certain question so it can be hard to find back xD
