Reply To: BC4-1810 Homework, Wilco Wilbrink
Forum Archive BC4-1810 Homework, Wilco Wilbrink Reply To: BC4-1810 Homework, Wilco Wilbrink
#41857
Wilco Wilbrink
    @smurfmier1985
    Hey, thanx!
    (images will follow in a few moments)
    1. To add stickers I do the following: First I load the picture in the UV/Image Editor:
    2. Then I select the faces that I want to use for the sticker:
    3. I press to UV-unwrap the selected faces. I use the option Project from View (So the view must be aligned correctly):
    4. Then I name the new UV-map in the Data tab from the Properties Window:
    5. I setup the following node setup (look at the bottom (yellow) framed nodes). The first node chooses the UV-map. Don’t forget to choose the correct image from the dropdown menu in the Image-Texture node:
    6. I align the unwrapped faces in the UV/Image Editor, while keeping an eye at the 3D View:
    I hope this explained it a bit. 😃
