@shiennar Your light match is as close as I’ve ever seen one. Fantastic investigative lighting work on a unique, uncommon light setup! One of my top favorites of the whole class A+
Your arch viz reads pretty believable. You’ve more than proven your ability to light and shade well, and it’s true here as well. My critique comes from the camera angle mostly. It feels like an unnatural placement: Too high to be a eye-level, but not high enough to be a more extreme, artistic angle that we sometimes see in notable arch viz renders. The focal length also looks a bit high to be realistic. Either the room is massive or there are no foreground walls to limit the camera’s location. So it ends up feeling like a set for a play more than an actual bedroom.
Does that makes sense? Am I guessing right that there are no foreground walls?
Its a B+ from me.
PS: I can’t thank you enough about cutting reels together again this month. You’ve truly created a class staple! I fully intend to incorporate an automated slideshow system in the future that mimics what you’ve started.
