@gradyp Yes, they are both matches. 🙂 The rim light is tricky here. If I want to extend it further, I either have to increase the intensity or make the lamp smaller. This will show up as stronger rim light on the areas that were already lit. I think the light you see on the beans is not actually the rim light, but an extra light thrown in for a good measure. But since my objects and materials are not directly comparable to the original, I don’t think I’ll be able to get a perfect match. (It’s difficult to say, but the top of the grinder might be metallic, in which case it will behave differently than wood when lit.)
