@smurfmier1985 Thanks I m glad if this has been of any help to you, part of my goal was to make examples on how to use the different modifiers and stack them, but also note the part of first planing, I blocked out the main shape withouth detail, then I sketched up the detail I wanted, and then I started modeling that out.
@yukinoh1989 I m very glad to hear that, I looked at several references to try emulate a victorian style that is in my opinion looked very nice for this project, it seems I managed to emulate it properly, as for the modeling of the patern, it was done by extruding edges on a plane, and scaling and rotating these, a solidify modifier was used then to give it volume, no modifier to do the pattern for you, but you could do something similar with curves and defining a cross section and a taper.
