@theluthier Thank you very much. 🙂 I think I’ll save you next week because I want to sculpt something that’s way beyond my current skill level. But I’ll try my best anyway.
Regarding the scaling issue, here are two pictures I made (in v2.80.21):
In the first one, I scaled the cube in object mode (to be able to enter precise measurements – I know you can use edge length in edit mode, but that gets complicated with more complex mesh). Then I apply scale. Visually the cube stays the same, but the dimensions are reverted to the original. I just randomly found out that when I toggle “Apply properties” in the ‘Apply Object Transform’ dialog, the dimensions are corrected. It only does that on the first toggle, though, then it stays the same. Not sure what’s going on there, but had I known this earlier I might have continued with 2.8. Oh well. Next week.
