Reply To: BC1-1808 Homework, Andres
Forum Archive BC1-1808 Homework, Andres Reply To: BC1-1808 Homework, Andres
#39922
Andres Altuve
    @smurfmier1985 Hi Miranda, answering your questions.
    how you the rotor nice and askew,?
    I created a cylinder with 27 divisions no cap, then added two edges on top and used the distance between the edges to get the thickness of the fan. Then added two more edges on the bottom part with the same distance. Then divided 27 by 3 since I just need 3 fans and got that I needed nine faces, so the next step is to disolve the top and bottom edges in the same 9 faces and finally join the top ones with the botton ones using the knife tool. Then deleted the faces i didn’t need.
     did you use a modifier or placed it by hand?  By hand, I only know two modifiers, mirror and subdivision surfaces.
    Is it attached to the middle part or have you stick it through? stick
