Shawn, I think that you had a comment in the main thread about a potential conflict between your loader arm and my engine housing. I think there is, and I am sorry it took me so long to respond. However, I’m also not sure if Kent is using my engine housing or Artifacts.
So perhaps you might want to check with Artifact to see if they have a potential conflict problem or not. I have uploaded my recent version into dropbox so you can view it here:
https://www.dropbox.com/s/88gojjldut9lk2w/Engine_block_04c_coord.blend?dl=0
The hood rotates about it’s origin there in the front, so just rotate it about the x axis about 5 degrees and you can see the conflict.
Sorry it took me so long to reply hope I’m not too late to help you out.
