Beautifully updated pipe work @adrian2301! Clean and optimal 👌
I watched that bit twice more.
Well deserved! Seeing someone go above and beyond is contagious in a project like this ✊
@jakeblended I’ve finished placing the 8 hydraulic lines from the swing frame to the digging arm. I can throw the file your way whenever you need it. It will probably be best to cut the lines off cleanly with fittings where my lines are come out on one side and yours come out the other (clean separation of work). Just lemme know!
