Forum Archive › At 16:10 – Jonathan snaps the extrude but snapping isn’t turned on › Reply To: At 16:10 – Jonathan snaps the extrude but snapping isn’t turned on
When snapping is turned on, if you hold control you disable it as you hold control, if sapping is turned off and you hold control, you enable it as you hold control. JL is using snap with control there to snap to the vertex.
