Reply To: Array using curve
Forum Archive Array using curve Reply To: Array using curve
#90741
    Yes, you can get rid of those gaps, if I understand you correctly. You just have to make sure the object you are using starts the same way as it finishes, so the beginning and end match and you get rid of the gap. Objects that have to follow along curves can get tricky. So if you can’t get around on solving it, maybe you can post screenshots and describe the situation a bit more so we have more context to determine what is happening.
